Horn - Alfa Romeo Bulletin Board & Forums
Old 04-02-2005, 08:22 PM
todds's Avatar
Send a message via AIM to todds
Horn
Can someone tell me where the 164's horn is mounted? I couldn't find it anywhere.. One of the notes is broken on mine and I bought a pair of Ferrari-style Italian air horns to replace it
Has anybody else mounted these on a 164? Where did you put them? How bout the compressor?
___
/<>/>/> (87 Milano Gold Automatic)
Old 04-03-2005, 05:22 AM
Alfisto Steve's Avatar
Horns behind and above area of left front fog light remove left front inner fender liner to gain easier access.
I mounted compressor on air cleaner lower mounting bracket but not much room to do so.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models - 91 164L w/AT "Black Beauty I" ALFA4ME; 91 164S Black Beauty II ALFALFA
In 230,000 mile Rehab MY91 "Bianco" 164B 5-speed [My Originale], ALFISTO
Daughter's current ride: Her Granddads 2002 Ford Taurus
Current Car hauler and Parts chaser : 2000 Dodge Ram PU 5.2L V-8
Old 04-11-2012, 01:38 PM
Hi, So do you two have compressed air horns? I need to purchase a new horn for my 91S and would appreciate your 'sound' advise, really how do they sound?
are they like the one at IAP:
Alfa Romeo, Fiat and Lancia Horns
or they have the electric one:
any preference? what would you choose if you were to do it all again (including the harder air horn installation issues)? thanks
Paul
1991 164S, 99 Eurovan, a Holder 20 sailboat (all old vintages). Drive well, empathise with lighter street users (bikes, pedestrians, skateboarders). No empathy for SUVs.
Old 04-11-2012, 03:50 PM
I am running an old 81 Lancia Beta low/high air horn semi-compact unit with both horn units in one body so it is small and mounts near headlight. I think I even left original horns in place. I just took wires off electric horns and used one of them to run Lancia compressor which is next to air cleaner.
If my 164B was A/T model I couldn't have gotten that Lancia air horn in there because of tranny oil cooler.
Virginia Beach, VA
Old 04-11-2012, 04:18 PM
salieri164's Avatar
When I bought my 164S, car came with FIAMM Serie TA (CH 2 038) E3 Air horns (made in Italy). Unfortunately compressor was weak so I can’t tell how it sounded with full glory. But knowing that PO was very knowledgeable about this car, I trust he made a good choice buying these particular horns.
Mounting was pretty straight forward and all within the same original location behind the front left fog.
I ended up swapping them with the original electric but if I chose to go with airs, I’d probably go with this same air horns as PO said it sounded very authentic.
I hope this helps.
1992 Alfa Romeo 164S
1991 Alfa Romeo 164L (sold) ///Anonima Lombarda Fabbrica Automobili///
Old 04-12-2012, 06:33 AM
dennism's Avatar
Whatever you do, mount the horns so that the trumpets are protected somewhat from water, and insects. If you face them forward without a baffle of some sort, they will soon be strangled. DAMHIKT!
Dennis Martin
'94 164 LS, Black
'91 164B, White
